Oil Leak Small block 360
Pan spacer. bro! There were tons of 340 go fast pans made then the 360 came around and it was like WTF, lets make a spacer so we can run our 340 pan on a 360...This guy made them once for under $40...Rick Liuzzo (570)561-1746
img_0823-jpg.1714619877
What happened to the oil pan spacer?
Is the pickup tube different from a 318 to 360
no, only difference is when you're changing pan styles
(and the oddball deep sump pans, but they require their own pickup anyway)
I dont know if i had an oil pan spacer. Ill need to check on it.
you don't
if you did, the 318 pan wouldn't have leaked
(running with the joke, why not)
The pans are different so yeah. The 360 pickups 8've seen will run too far up into the front of the sump and starve the pump on accel.
Iirc Im running a 360 p/u with a couple inches taken out. But my memory, ehhh...
