1966 Dodge Dart GT rear seat belts??
coalman
Texas
I am looking at installing rear seat belts in my car with bolt in anchors for two people, any recommendations would be helpful. Thanks
I am sure I have a set of seat belts for a 66 Dart. They came out of my 270 Dart. They are red. I have no use for them. Let me know if your interested or need pics.
Rod
Rod
Thanks for the reply, I need black, I guess I could dye them, mostly interested in the floor location for the anchors and anchors, none were ever in the car. Send some pictures of what you have please. Thanks a bunch....
Give me a day or 2 and I will get you some pics of the belts. I did a mini tub on mine and I cut out the anchor section. I just cleaned up a lot of the old stuff I had laying around for a year or so and I think I may have thrown out the anchor section but if not you are welcome to them. Pm me your email so I can get you the pics.
Rod
Rod
Anchor location and anchors would be great! Thanks I will get the PM out sometime today...
Your inbox is full, I am just interested in the seat belt floor anchors.. Thanks
When you say floor anchors are you referring to the bolts to fasten them down?
Rod
Rod
I guess, the car never had them, there are no holes for them. Location is a problem also, looked them up in shop manual, hard to tell by the picture... Thanks
Here are the pics of the anchor bolts I thought you were referring to.
Rod
this is my 66 convertible. they had seat belts in the rear.
the darker section is a 72 dart floorpan modified in the front seat area to use 97 sebring seats front and rear but the spotwelds are the same as the original 66's welds. car is on a rotisserie and flipped on it's side to view the undersidein pic #1
ignore the second arrow pointing to the rear there is only 1 hole in side of the rocker panel that is threaded.
this is the top view of picture number 1
hope this helps.
hope this helps.
Thanks for all the effort, I actually found the holes they were plugged. I thought I had posted that somewhere. Again thanks...
