jazak5 Well-Known Member Joined Aug 6, 2015 Messages 1,556 Reaction score 873 Location NY Nov 11, 2016 #1 looking for photo's to correctly install the manifolds //ordered the special hardware kit and need the proper location of the studs/spring washers ect.
abodyjoe Well-Known Member Joined May 22, 2004 Messages 24,385 Reaction score 13,731 Location Berlin,N.J. 08009 Nov 11, 2016 #2 when you get them look at the manifolds and look at the hardware kit. it will be obvious... i just installed a set in october..
Johnny Dart Well-Known Member Joined Nov 30, 2006 Messages 8,736 Reaction score 3,998 Location So Cal Nov 11, 2016 #3 Keep in mind that some of the studs go into the water jacket, and need a sealant. I prefer permatex high temp thread sealant.
Johnny Dart Well-Known Member Joined Nov 30, 2006 Messages 8,736 Reaction score 3,998 Location So Cal Nov 11, 2016 #4 Here are a couple pics of a 340 I'm working on. Hope they help. Last edited: Nov 12, 2016
4spdragtop FABO Gold Member FABO Gold Member Joined Aug 28, 2009 Messages 39,446 Reaction score 22,719 Location Ontario Parts Unknown Nov 11, 2016 #5 Beautiful JD!
jazak5 Well-Known Member Joined Aug 6, 2015 Messages 1,556 Reaction score 873 Location NY Nov 11, 2016 #6 that helps/studs with nuts go to the ends (water jacket)long nuts self explanatory
jazak5 Well-Known Member Joined Aug 6, 2015 Messages 1,556 Reaction score 873 Location NY Nov 11, 2016 #7 ok another question/// is it factory for a 69 340 have the spark plug heat shield ????? I've seen some with and some without
69_340_GTS Well-Known Member Joined Jul 11, 2014 Messages 4,808 Reaction score 3,771 Location Torrington, CT Nov 12, 2016 #8 You do need the shield on the driver's side. It will really help to keep the wires from burning up. AFAIK that was a standard factory installed part.
Johnny Dart Well-Known Member Joined Nov 30, 2006 Messages 8,736 Reaction score 3,998 Location So Cal Nov 12, 2016 #9 Get your Gold Card out for the part.
abodyjoe Well-Known Member Joined May 22, 2004 Messages 24,385 Reaction score 13,731 Location Berlin,N.J. 08009 Nov 12, 2016 #10 69_340_GTS said: You do need the shield on the driver's side. It will really help to keep the wires from burning up. AFAIK that was a standard factory installed part. Click to expand... i didn't put one on.. freaking thing is about $300
fratzog lover Well-Known Member Joined Jun 7, 2013 Messages 18,985 Reaction score 21,345 Location Northeast Alabama Nov 12, 2016 #11 Mopar Performance Exhaust Manifold Heat Shield
abodyjoe Well-Known Member Joined May 22, 2004 Messages 24,385 Reaction score 13,731 Location Berlin,N.J. 08009 Nov 12, 2016 #12 ahhh. cheaper then i remember
fratzog lover Well-Known Member Joined Jun 7, 2013 Messages 18,985 Reaction score 21,345 Location Northeast Alabama Nov 12, 2016 #13 Maybe they just aint flyin' off the shelves.
