In this case, the extra cubes amount to 3.3% and 6.3%
I wouldn't expect the 372 to run much different. But the 383, if it is a BB with it's shorter stroke, might be even worse.
Personally, while I can live with a soggy bottom end,a big TC, and race gears, I don't like it.I much prefer dumping the clutch at like 1200 and motoring away. And while 4.30s are fun on the street,on weekends; I found them a royal PITA in my clutched DD.
Personally, I like running the compression on the edge of detonation but not yet into it. The engine response is immediate without bog or hesitation from well below 1800rpm; taking full throttle with a 750DP and with a 10.7 starter gear to perhaps as low as 1500 rpm.I like lighting up 295s like it was a BB. I like getting fantastic fuel mileage. I like being able to jump in and drive a 1000 miles on a weekend,not having to have saved up for months, to be able to afford the trip. I like putting the hammer down at 30mph in second gear, not having to downshift to blow some punk off.I like being able so slide through a turn, feathering the throttle to maintain control, not having the engine revved up to the moon. I like running a small cam, and letting the heads and compression do all the work;INSTEAD of a 2-sizes bigger cam and a 3500TC and 4.30s.
I challenge any SBM streeter that is currently running their Dcr compression in the basement,a 3500TC,big gears,and a ferocious cam, which is sortof a pretty good combo; to back up the bus. Rebuild it with a 223 to 232 at most cam. Reset the Dcr to the max. Pull that 3500 in favor of a 2400/2800. Pull that 3.91 x 2.45=9.58 gear in favor of a 2.74 x 3.55=9.73starter And install some matching heads.
Now go out and tell me how much more you like the new combo.
And when gas goes to 8.49 a gallon,try to remember what a pig your old combo was on gas.
Some guys do not put much emphasis on compression, and rightly so for a drag racer. The difference in ultimate power is not that significant, from the torque peak to the power peak and up to trap rpm.
But we streeters don't spend a lot of time up there. And from idle to the torque peak which is where we DO spend most of our time,the difference from a Dcr of 7 to a Dcr of 9 is a HUGE difference in torque and thus a very significant difference in power, and the fuel useage in steady-state cruising I have proven to be up to 100% increased. For an SBM streeter, and especially for a streeter that is gonna spend some significant time on the hiway, IMO, compression is a very big deal.
If you are putting pistons in anyway, IMO, it behooves you to pay very close attention to your FINAL Dcr, and run it as high as you dare.It costs very little more and pays back bigtime.
Consider even what the auto industry is doing. Are they still running low Scrs? No! We are seeing Scrs now that are mostly higher than they ever were in the glory days of the 60s and 70s. Do you think they might be on to something?
In truth setting the Dcr up to the max, might actually cost less, depending on your combo;by the time you add up the installed cost of the big TC and the rear gears.
My 367 is running; Scr 10.9/Dcr 8.6/175psi/aluminum heads/87E10 .
A few braver-than-me fellows here, report that they are successfully running Dcrs with their aluminum heads into the 9s, and pressures over200psi. I think I recall one fellow successfully running 9.2Dcr on 91 gas. If I ever get a do-over, I am definitely gonna pump mine up higher. The throttle response and fuel-mileage alone are worth it to me.
Notice throughout this post, I refer to IMO.This is cuz these are the things I have experienced with my three iterations alone; the 292/508/108, the 270/280/110, and the 276/286/110 cams, and various Scrs from 11.3 to 10.9; over a period of over 14 years and a distance of over 100,000 miles.
To me, a 9.5 engine is not worth building,from scratch, for a SBM streeter. To me if I was stuck with one, I would not slide much cam into it. If I was broke and couldn't afford to pump it up, I would drive it with the factory cam in it, and save up for pistons.
I'm not saying there is anything wrong with a 9.5 engine! I am saying if I have to rebuild it, the proper pistons are chump-change more, and will very substantially improve your first gear performance, and most especially your fuel-mileage, and your off-idle to about 2400 rpm torque, and throttle response.
See SBMs are cubic inch handicapped, for a muscle type car. So you really have to squeeze them to come alive. A 9.5Scr 440, well that is a beast. Sure Dynos have have shown even 8.5 engines making plenty of power, Again, from the torque peak to the power peak. For a Streeter I say SO WHAT! We don't spend a lot of time up there! But every time you start off, you are passing from idle to about 3500 rpm. What sense is there in having 400/450 horsepower at 5800, and you need a 3500TC/3.91s to drive through the hole you just created from idle to 2000rpm? No, friends, FAR better it is to have more modest small-block power, and gobs of torque to pull 3.55s and a 2400TC. So what if it takes a few milliseconds longer to hit 50/60 mph.The tires are gonna be spinning most, to all, the way there anyway.So what indeed.
For you guys with Desk-top Dynos and similar programs, I'm afraid they won't report this stuff. So don't waste your time trying to prove it. These programs are great at what they do, but by and large they are very focused. And not on daily driving,lol.I shelfed my early version in 2004, and haven't revisited it since.
So anyway, that is my opinion.
