[SOLD] 8 3/4" narrowed rear end
RockinRobin
Corsicana, Tx
Rating - 0%
0   0   0
Narrowed for full tubbed A body. 3/4" stiffener welded to rear. Moser 35 spline axles with 5x 5" bolt pattern. Moser spool. new bushings, bearings and seals. 4.56 gearset has broken tooth on ring gear. $150 plus shipping from 78642.
What is the width? Flange to flange?
Housing flange to housing flange: 46 1/4"
Axle flange to axle flange: 51 1/4"
Perches center to center: 28", 3 degree downward pinion angle.
Axles are large brake drum hole, 5x5 pattern, extra holes for 5x5 1/2 pattern.
