Left hand studs for an A body are no longer available, and yes, left hand studs have an "L" stamped in the ends. Many of these cars have had the studs switched over to right hand thread over the years. What is bad though is that in some cases a broken left hand thread stud has been switched to right hand thread and the other studs left unchanged. Before making the change over, make sure you can get all the right hand studs you need for both front and back, and possibly a new front drums since the front drums have the studs pressed in place. You may find that front drums are difficult to find as well.
