[SOLD] 1966 barracuda will be parting 3/12/17
My son who is autistic is building a 440 and putting it in a 66 barracuda and he needs alot of parts like front bumper rear taillight assembly's etc and center console
Front bumper is damaged, will be update with console, taillights already have a claim
Need trunk lid prop rod with both mounting brackets, front grills (If the others pass on them), center grill, Barracuda fender emblems, top fender turn signals, trunk latch cover box if not smashed, reverse tail light lenses...thanks
Trun
trunk rod, with mounting brackets, center grill,barracuda fender emblems, only one fender turn signal pass side, (the trunk lock cover I am keeping if good,tail lights are claimed) your claim for others are noted
Is the rear axle 7.25, & if so is it a Sure-Grip, & if so what $$$ for the carrier & gears to 15301 ??
I'm interested in the rear window gasket center strip lower corner aluminum corners for the strip. If in good shape.
Thank you,
Syleng1
Hi, I´m interested in the fender mounted turn signal, if you have the other one, I will take it too.
Thanks.
Inner fenderwells and plastic rear window support covers? PM me cost before you hack.
from post #27
From my earlier post....Also add headlight bezels and metal horn cap
A couple of close pics would be appreciated...Check you inbox I sent you my email address. Thank You
