benz junkie
Member
I have a 1976 Fury Salon that will crank and start very briefly but will cut off almost immediately. The engine will not run on starter fluid or if you hold the throttle down. It just starts and then shuts off. I was wondering about the ignition once it goes from the start position to the run position.
