1965 barracuda trunk privacy panel
RJG
Oceanside, CA
Hello FABO,
For a 1965 barracuda, it seems that there are two different shapes for the tilt-up trunk separation panel. One type extends on the right side to enclose the quarter panel void. The other type does not have that extension.
I know the 'S' has a kidney shape for the wider tire. Did the factory also eliminate that extension?
Can someone educate me on why there are two different shapes.
Also, do both types have the metal edge trim cap for the top and side edges.
RJG
RJG
So yes there were two types.
1 the extended version was for the non defroster cars
2 the cut off version was for the defroster cars to get air from the trunk area that was suppose to be warmer (maybe who knows) and blow through the vent to the back window.
If anyone has pictures of a defroster set up please post them!
RJG
Thank you, that is very interesting. I have only seen one set of dash switches for the heat. Do you now where the switch for the defroster was located, or what other extra material/equipment would be in those cars to make the defrost?
