[SOLD] 1967 Plymouth Valiant
71valiant
Make fast, break, repeat.
Columbus, Indiana
67 Valiant. 360 .30 over. Ross forged pistons, Eagle rods, 10:2 compression. Mopar steel crank. Mopar 528 solid cam, Edelbrock RPM intake, Demon 750. EQ heads. Maybe 300 miles on engine. 8.75 rear with 3.90 gears, cone sure-grip, 489 case. 727, 3800 PTC stall. Hellwig front and rear sway bars. Minitub with narrowed rear. Running 295's right now. New rear brakes and hardware. Tons of stuff done to it. I just put a new fuel setup on it. If serious please pm me and I can go into more detail.
12500.00
I haven't spoke with the gentleman I was in the trade with for a couple of weeks. I'm assuming the trade has fallen through. So it's back up for sale I guess.
Heres engine specs.
Edelbrock Performer RPM intake manifold #7176
Engine Quest magnum cylinder heads, 62cc closed combustion chambers
10:2 compression ratio
2.02/1.60 Scorpion stainless steel intake/exhaust valves
Comp Cam beehive valve springs
Comp Cam rocker arm studs #4504-16, ARP polylocks #300-8241
Comp Cam 1.6 ratio adjustable rocker arms with roller tips #1416-16
Comp Cam pushrods
Felpro gasket set with Q1008 head gaskets
Mopar LA 360 engine block bored .030 over
Ross flat top forged pistons with full floating wrist pins #99627
Piston top .004 below deck, piston to cylinder head quench clearance .043 inch
Sealed Power moly piston rings
Eagle SIR forged steel connecting rods with ARP rod bolts #6123CB
Mopar cast iron crankshaft, external balanced with Mopar front damper
Standard sized tri-metal main and rod bearings
ARP crankshaft main bearing bolts #140-5001
ARP cylinder head bolts #144-3602
Mopar .528 Solid Cam and lifter set
Engine Pro double roller timing chain and gear set with 9 keyway adjustment
Mopar magnum timing chain guide set
Melling high volume oil pump, pickup tube, and drive #M72HV, 72-S2,IS-72
Kevko 6 quart oil pan with internal baffles #M302, M301-1
Heres engine specs.
Comp Cam pushrods
Any video of it running ?
