Busterme
Member
Hey everyone .can someone tell me if a eldelbrock air gap intake fits under a 67 cuda with a 360 with stock hood i would be trying typical 4 barr carb and air cleaner
Right now the 360 is in a Dodge pickup with a stock Carter AFB carb stock manifold cuda still has it's original formula S 273 that I'm pulling for the 360 because it has 128 thou miles and uses oil badly I'm considering eldelbrock top end upgrades to 360 before swap. I'd like to keep the upgrades down below 3 grand . So my plan is to keep 360 bottom end untouched hopefully upgrade to eldelbrock heads /cam/lifters/ and carb . Just ordered Doug's headers this is so i can possibly drive it to Chrysler nationalsI think it will depending on your air cleaner base plate. With the right "drop" (carb base plate) you should be able to get enough space. What intake are you running right now???
Treblig
Ditto, same deal.You will need a drop base to use that intake.
I got the drop base and air cleaner from Mancini Racing.
