Car won't start. Could miss Carlisle! Please help.
domdart
Johnstown, PA
My 68 Dart would not start this morning. I put a 72 340 in it last year. It always starts and runs fine. The last ride was on Sunday, no problems. Normally, I turn the key, it starts, I let go of the key and give it a little gas and it runs at idle fine. This morning, I turn the key, it starts, I let go of the key give it gas and it dies. I tried about ten times. It did the same thing every time. I plan on driving it to Carlisle Saturday morning. Any advice will be greatly appreciated. Thanks.
It's the ballast resistor in the ignition circuit. They should have one at your local parts store. I carry a spare in the glove box at all times.
Thanks for the reply. I work till 11:00. I'll pick one up on the way home. I keep an ignition box and a coil in the trunk with some tools. I will start carrying an extra ballast resistor.
x2 Sure sounds like a ballast resistor. The engine will continue running as long as you have the key in the crank position. Not good to do but as a test for a few seconds.
x2 Ballast resistor. The engine will continue running as long as you have the key in the crank position. Not good to do but as a test for a few seconds.
I looked at my Summit Racing account. My coil came with a ballast resistor, so I already have one. I'll still pick-up an extra.
You can bypass the ballast resistor briefly. I once used a little piece of hose clamp to connect those 2 female terminals together so to drive the car to the part store.
The coil would eventually over heat and some will spill their oil fill on the intake.
mopar part# 33000682 there a 16 in stock in canada , likely even more on your side of the border!
Double check your grounds. Clean and tighten bulk head connections and others as well.
FWIW .........
Is that the resistor part number or the iggn. Box?
Resistor , it is for the starter on 83 to 93 jeeps(forget what model)it looks the same and has slightly less resistance then ballast resistor , have clients been using it for few years no problem gives close to 10v at coil instead of 9 to 9.5 , also depends on charging system...
you cant try to use the balast resistor from the wiper motor to get you home
