[Found!] 3/4 fan spacer
if yours is aluminum go around it perfectly with 3/4" masking tape and carefully cut to the tape all around and then through.Finish file it square.It's easier than you think
Did it, nailed it!!! Thanks.
Took longer to square it up than to cut it.
