1970 Duster 340 Looking for build sheet or any original paper work
davescuda
Cheshire, CT
VS29H0B279870
thanks
I have a photo of the fender tag, but nothing else.
Did you sell Dave the car he is looking for info on? Do you have info on many 70 340 Dusters? I have one I'm looking for anything like previous owners and build sheet. Its a matching # car with vin match on radiator support and trunk rail and it still has the fender tag as well.
If it is a '70 model from Hamtramck or LA there are Registries that include all models from those two plants.
I have never owned Dave's car, but I do track histories as details are available.
More info at www.hamtramck-historical.com
Also.......
Trunk rail number would be very odd for a 1970 Duster.
I've checked hamtramck before but there is nothing on my car ending in 6315. Can you post links to other registries that you know of?
Is that the Duster that I sent you the block for?
There is a 'links' button on the site, check the clickable buttons at left.
Also, the VINs listed in the found section are all for items I have here.
If a registry member has an item that they reported but kept, that information is not listed there.
I can not advertise items I do not have.
So anytime anyone with a 1970 Hamtramck or 1970 LA built car takes the time to register, I check to see if I have a hard file on the VIN with any matches. If a match is found, I ask the person with the item if it is OK for the car owner to contact them.
no this is the duster you sent the block for.
That's a really nice job you've done there - maybe I should have took that one instead of the pink one.............
