70DusterBob
I asked the FABO member halifaxhops if he could rebuild a distributor for me. My engine is a 1975, 360, but it is modified a bit, not a lot, but he said he had a 1975 distributor he could rebuild for me and put an added 2 degrees to the vacuum advance for me. Well he did, and I put it on. The engine really improved, I mean significantly. It accelerates much quicker when not in gear, and when driving there is a noticeable improvement.
I had an “Over the Counter” Cordone that was rebuilt which I got from a parts house in it. The years it covered were from 1972-1983 I believe... Way to much of a spread for it to be accurate for each specific engine’s needs. The difference was night and day. You would think I had bought some kind of performance kit and installed it. I mean it wasn’t like nitrous, but it really brought my engine to life. And he gives you a spec sheet so you know what the distributor’s specs are.
I highly recommend halifaxhops when it comes to rebuilding distributors. He will rebuild mine the next time it needs it, for certain.
His name is Ray...
His name is Ray...
