Has anybody got a part number for a 20 pound radiator cap that will fit a stock 26 inch 2 core 340 radiator? This 16 lb is not doing the job.
Jack
Jack
yeesh - no need to get all personal and everything with the guy... what'd he do to you!?I think you have other problems
It could even just be a bad cap, as there is no reason for a 16lb cap to do that unless it's getting hotter than that.
(well, unless there is a compression leak in the block somewhere)
IMO, replace the 16lb cap, and if that doesn't do it then a recovery system.
Remember, a higher pressure cap will just put that much more pressure on all your hoses, radiator and heater core.
O'Reilly Murray part # 7020.
Damn yall, the dude has a blower on his engine. Might be a little different than the average bear, ya think?
