AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 26,611
- Reaction score
- 13,844
Before I would do anything, I would do a compression test with a top-quality screw-in tester.If you have about 162 psi, then you already have the most torque from idle to 2500 that any teener will ever make. And so almost any cam you put into it will rob low-rpm cylinder pressure and trade it it for midrange, mostly.Trying to get that little B off the line will then be slower than it is now........unless you also put in more TC and or upgrade the rear.
This is about what you should have now, if you really have a 9.2 engine;
Static compression ratio of 9.2:1.
Effective stroke is 2.86 inches.
Your dynamic compression ratio is 8.07:1 .
Your dynamic cranking pressure is 161.70 PSI.
V/P (Volume to Pressure Index) is 133.............................................133
For pumpgas, this is close to the maximum you can run.
So, if you have 160ish, then you have a great base from which to build, so don't spoil it all with a slow-ramps Summit cam, especially with that big ol' A/C compressor in there..
Here's what the 6901- 276/288/114 will do for you, in at the 109 recommended install. This makes an ICA of 67*
Effective stroke is 2.50 inches.
Your dynamic compression ratio is 7.18:1 .
Your dynamic cranking pressure is 138.80 PSI.
V/P (Volume to Pressure Index) is 100..............................................100
That's giving up 33 points of VP, and 23psi of cylinder pressure!
that's a lot of torque to give up in a B with 2.94s and a factory convertor.
This is a very slow-ramp cam. The .050s are 218/228. So on the intake 276 less 218 =58 degrees of ramps, about the slowest out there. sure, the overlap is 54* so you'll get a little lope, but it will be a huge disappointment when you put it into low.
For low-speed torque, your teener is already at the top of it it's game (with a true 9.2 Scr and 160ish psi.). So if you are looking for a bit more off the line, a far better idea IMO, is more off-the-line rpm. Like a 2800TC, I love those. This will about double your available take-off torque. Maybe more as I have no idea just how low your torque number currently is with the 1750factory TC.
But that 2800 is about at peak torque on a teener, so it can't get any better,lol! If you still want more, the next thing would be more gear.
And then a custom cam, with a similar ICA to what you currently have.
But this is all based on the compression test. If your pressure is more typical, at 140psi, then just forget about a cam period. Unless you are also prepared to get a bigger TC. And so you might as well get the TC first and see how you like that.
Psssssst 2800. I love that thing. I guarantee you will too. In my 3650 Barracuda (me in it) It's like a slingshot. From an idle, I hit it. The rpm spools up, the TQ-secondaries open,and then........then chit happens.
