[Found!] Wanted Mainshaft
Jordan2840
Active Member
St. Louis, MO
Rating - 0%
0   0   0
Anyone know where I can find an A-833 mainshaft? 23-1/4" in length. 30 spline. I have miscellaneous parts I can trade or purchase outright. Thanks in advance
Is 23 1/4 inch for an A body trans? Your ad really doesn't say.
I have a mainshaft, but I'm pretty sure its out of a B & E body A-833 trans.
Don't want to get it out of storage, as it's buried deep, if it's not what your looking for.
I believe so. My transmission guy said I needed one with those measurements. With also 40 spline 1 & 2 hub and 40 spline 3 & 4 hub.
Well then, what body style Mopar you guys working on anyway?
Since this is an A body site, i would assume it's an A body car.
Depending on what is needed, consider a machine shop to repair yours. I recently had a worn input shaft bearing surface spray welded and machined for $160ish.
