69 Dart Headliner Install / sail panel question
Fabman
Always been MOPARS
Central Florida
When installing the headliner on a 69 Dart...does the sail panel have its own "Covered" board piece?
Does the main headliner go all the way down and also cover the sail panel to form a single , one piece headliner install over the entire sail panel?
The headliner should go all the way down to the back dash covering the sail panel board having a continuos look from the the front to the back dash of the car.
Hi Mark, Matt is correct. One continuous piece all the way down to the C pillar covering the sail panels. Dart looks good, any more pix?
Hey Mark ! I tried emailing you this morning with pics- but the email is no longer correct.
Thanks for the pic Matt ! Just what I needed. Now do you have any detailed pics of what the rear window trim pieces look like ? Same question for the front windshield. I don't think I have those pieces that's why I need the pics.
Here is a few pics of the Dart to date...
Fabman...if you look in that picture the black trim around the rear window is what you need. It was 2 pieces that covered the seal of the window. For the front windshield the window seal is all that was there. No trim for the front.
You mention 2 pieces, they go all the way around the window? They cover top, bottom and both sides?
A close up picture to show profile of the trim would really help if you have one.
Did the factory ever use the black trim with a white headliner? Im going with white seats, door panels and headliner . I am not sure what trim colors were used.... Ive seen it both ways but not sure if the black was factory.
2 pieces will cover the top and sides only. There were not any on the bottom. I'll see if I can find some pics here a little later
