charging system blues
The other alternator is wired for the earlier style voltage regulator.
On your '71 voltage regulator:
Blue wire monitors system voltage. The regulator decides what to do based on this voltage.
Green wire is the alternator's grounding wire. The Voltage Regulator controls the power flow through the field to ground.
Voltage regulators before 1970 control the power to the field positive. Field negative goes to casting which is used as a ground.
looks like one will not work in the others place - i bought the single pulley thinking the only diff would be a/c or no a/c - have to wait till tomorrow now
If you want to bring it by, send me a PM. Put the old alternator back on and we'll figure out what, if anything, is wrong when you bring it here.
tomorrow i'll take this single pulley back & get what was on it - double pulley with the two fields.
There are two alternators, a roundback and a squareback.
Single or double pulley is for AC and double belt systems like motorhomes or trucks with big fans.
You have and want a squareback, but with a single pulley, but last I got one they told me they only had 2 pulley because it would work for a car or 2 belt system.
(Probably BS, but it was all they had around here locally)
You ... want a squareback
True. For a non-restoration, these generally perform better at low rpm compared to a similarly round-back with the same rating.
There two styles of alternator housing from the 1960s through the 70s. A point of clarification because this
You have..a squareback
is only true if a later alternator was installed.
The squareback was introduced in 1972.
http://www.hamtramck-historical.com/images/serviceHighlights/1972/1972 sh p24.jpg &
http://www.hamtramck-historical.com/images/serviceHighlights/1972/1972 sh p25.jpg
All 1971 cars originally came with an isolated field round back alternator.
These were introduced across the 1970 product line. http://www.hamtramck-historical.com/images/serviceHighlights/70 sh 71.jpg
These are mostly of interest to someone restoring a '70 or '71, especially if it has the correct casting number and date on both halves.
A pulley swap is relatively easy. Most traditional parts stores will do that for you.
I was going on the assumption that he has the square back now and was intending on replacing it with one, because he said he has two field wires on the back of it.
I was more trying to clarify that the one/two pulleys makes no difference as far as function or type of alternator.
The places around here won't swap a pulley for you, but they will rent you the tool to do it.
Let me come right out and say it. This is wrong. Round back alternators from 1970 throught 1971 had two isolated field terminals and wires connecting to each. Same wiring as used on the squarebacks starting in 1972.
Please look at the 1970 and '72 Service Highlights (links above) if you have any questions about this.
Please do, I ain't delicate like some people.
Learn something new every day, as they say.:D
Thank you.
here with car now - alt on 1st. cranked up charging @ 13.6-13.8 . good charging voltage anywhere i check with meter. i'll leave the vr alone - its likely better than the one i bought - standard ign vr made in China. on with a remy reman alt -square back dual pulley 60a like i took off. i thank everyone who responded. i have a better understanding of how this particular Duster charges. in time for a couple shows this w/e
"Here's the thing" about roundback/ squareback.......
Yes roundback ISOLATED (sometimes called "dual field") were made up until squareback, BUT THE THING IS
cheap *** rebuilders have "converted" a lot of older GROUNDED field into the 70/ later ISOLATED FIELD and done so INCORRECTLY.
WORSE, some of these "converted" units "somehow" get GROUNDED BRUSHES installed, AS WELL AS up through "squarebacks" ALSO COMING THROUGH with grounded brushes or broken or missing brush hardware which INCORRECTLY causes one brush to be grounded.
ALWAYS CHECK that your "isolated field" REALLY IS isolated!!!! Neither brush should be grounded!!!
Below, on left is one I did not know was made until recently, is it Mopar or aftermarket? If you look closely it has a GROUNDED BRUSH installed, yet it has a spot to mount 2 ISOLATED brushes:
(On the right is a "regular" squareback)
[/URL]
this God Damned software!!!!1
Below is one of the "junk mexican" rebuilds this is a 69/ EARLIER grounded brush unit that has been "half ***" converted to isolated field:
At 6 O'clock is the position for the old grounded brush. The "half ***" brush is at 12 O'clock, they just drilled a hole and popped a screw into the case
Below is ANOTHER one "you have to watch out for." This APPEARS to be a "normal" squareback WHICH SHOULD BE "isolated field" BUT IT HAS ONE BRUSH GROUNDED
You know the easy test for this is just to disconnect the battery NEGATIVE cable,with the engine idling. If it stalls, the charging system ain't putting out. If it didn't stall turn the headlights on. If it stalls now, turn off the key reconnect the battery,.
I wish to hell I could get people to NOT do this. It does not really prove anything and can damage electronics including alternator diodes.
If the engine quits, it MIGHT mean the alternator is simply turning too slow.
