Plug wire grommets commando valve covers
txas2step
houston
Looking for the grommets the hold the plug wires on the finned valve covers.Any help appreciated. Chris.
What year vc's? Grommets were different thru the years I believe.
67 had white plastic clips that snapped into the finned part.
You need 4 of these. Maybe RT Specialties?
Just a heads up, large aftermarket wires wont fit into those looms.
Dang link wont work on my phone. I see its Year None. Only and only reason I would ever buy from them is if no-one else sells it (M&H harness)
After speaking to them about Interior door panels, I will invest zero time n money in them
LOL Kiss my rosy red azz! Who was the clown that wrote the the application paragraph? 66 and 67 you only need 4? 4 whites and 4 greens? What are they talking about?
My mistake, 2@ $28..8 per car, 4 per 1 per car? They can still blow me.
Here, 300 8mm ID for $12... just slit one side
uxcell-300-pcs-8mm-inner-diameter-white-rubber-armature-bar-firewall-grommets_25440479.jpg
Well, that's what they are...... $6/$7 each anywhere that sells them...X 8 = $48/$56 a set. I bought mine for $25 for 8 of them years ago.
Guess it depends how correct you want to be.
Hey, how's it going? where can I get me some of those white grommets that you are showing in your picture Pishta?
Thanks, but I am looking for those white grommets to use as inexpensive replacements for the 1964-65 273 wires.
