What makes it a "specialty cam" ?
toolmanmike
Moderator and forum fixer
Staff member
Office
The lobe catalog does not list any manufacturers. There are some violently fast .904 lifter profiles available, but they not stupid enough to make them shelf grinds and suffer the "why did my cam go flat? Must be the manufacturer" bullshit.
Mike if you are looking for a nice cam , I am running a JEGS #555-200161 in the 273. I also used this cam in a 318 Aspen and a 360 Charger. Works well. Summit # is SUM6901 same cam. Just sayin'.
Comp actually has many lobes for .904 lifters. The trick is know which lobe to use.
Correct. I was just looking through their lobe catalog and they have some real good lobes but some are so aggressive they need extra oiling to make them live so they don't use them on shelf cams, just something you can special order
I didn't know they were still around. I know they made the manual Transmission 340 cam in 68. I will have to look into that.
Thanks for the info.
If you call Racer Brown (and I think you should...I'm using his cam right now) make sure you call him AFTER 5 PM eastern time. That's when he answers the phone. When you call, you talk to the guy who does the cams. JIm is his name.
Hey Mike, I will sell you a 3/4 RACE cam !! man it is special !:lol:
That's what everybody needs.
Well its only a 274/283 at 0.050" so for what I normally make yes its a 3/4 race cam. HA HA HA
"3/4 and full race" was back in the day where a 300°/.500 was pretty racy.
