[WANTED] 1973 Duster 727 Speedo Gear assembly and retainer
Zam1787
Active Member
Myrtle beach sc
I have a 1973 Duster and i just installed a new Performance Automatics 727 transmission. There was a plastic piece slipped in to the trans where the speedo gear and assembly and horseshoe retaining clip are supposed to be. Im looking for the whole assembly and bolts to plug and play. Thank you!
You will need to know your rear gear ratio and rear tire diameter to get the right speedo gear. Here's a chart:
I am running 3.55 gears, and I have not chosen tire size yet. I have 17x8 rims that im going to try to "fill" the standard wheel wells for a street car. If someone could point me in the right direction i would appreciate it
You will need the tire size before getting the proper gear, here is the retainer I have sure I have a oem bolt for it also.
Is this what you need except for the speedo gear?
Ken
Edison, NJ
