1957guy
1957guy
I have a '65 Dart with a 225 and A/T. The engine has an Offenhauser 4V intake and the trans is a later model 904 with mechanical shifting (not the '65 cable shift).I also have the Offy linkage kit# 5270A.It's clear that this linkage kit is designed to work with a vehicle that was equipped with a throttle cable.I've managed to use some of this kit to correctly activate the transmission throttle pressure lever but it's not clear on what to do for the main throttle since the gas pedal is floor mounted.
Does anyone have the hot tip on 4V carb/pedal/linkage system for the early A bodies?
