Wouldn't you just use a standard fram or wix between the mechanical pump and the command unit?Looking for suggestions for fuel filters..
running the FiTech FCC so I need a low pressure pre filter, and a hi pressure filter.
What's the good, the bad, and the ugly?
Wix 33270it's been said the supplied FiTech filter is subpar and passes particles larger than the injectors can pass. Some of them even having the flow direction stamped backwards, I'd rather go to something better than gamble with issues.
as for the standard fram or wix, what PNs?
The Wix 33270 is a wire mesh 141 micron filter, I would use the 33033 cellulose 20 micron pre-filterLooking for suggestions for fuel filters..
