satchall
Active Member
my 72 is currently charging at 16-18 volts and i have no clue why. Replaced ballast resistor, voltage regulator, and trace wiring to ensure it was not too brittle. Any thoughts?
My only thought about the alternator is that if it were the problem wouldn’t it be stopped from cranking out too much power by the voltage regulator?Here's what i'd do in this order:
Check the battery to engine block negative cable, make sure both ends are clean and tight
The voltage regular ground from the factory was crappy at best. Run a ground wire from battery- to the voltage regulator body. Scuff up the body at a mounting bolt and mount it there, or add a little screw to the side of the regulator body and add the negative wire there.
Check the FLD wires at the alternator and make sure they're clean/tight, and trace them through the wiring harness if needed to check for any breaks/damage.
Check the bulkhead connector as well as the connection quality at the ammeter gauge behind the cluster.
Lastly, it could be a problem with the battery. Take the battery off, charge it to full, and reinstall it. If the same symptom occurs try another battery if you have a spare. It could also be a faulty alternator. I'd check all of the above first.
So probably not the alternator?Not the sort of thing an alternator does. Unless its been apart and a brush insulator is broken or left out.
Battery plus in on one terminal, ground on the other. Now its not a 100%ground,it’s regulated. 100%ground is called “full fielded”.
Probably not, it can in rare cases where a rotor winding shorts to the rotor body near the field end connection slip-ring. But it's 99.99% not likely.So probably not the alternator?
Correct with the regulator and alternator. So where should i start to check the bulkhead connection?Probably not, it can in rare cases where a rotor winding shorts to the rotor body near the field end connection slip-ring. But it's 99.99% not likely.
Most common cause is a poor connection from the power to ign. feed all the way through to the wires to the ballast/regulator/alternator B+(usually Dk. Blue). Any and
all connections including bulkheads at the firewall, column connector, ign. sw. itself, splices, etc. If any of these is poor, the regulator sees less V than the battery, so it
thinks it hasn't charged enough yet. The blue wire at the reg. may be seeing 14.3V while the Batt. may be seeing 16.2V. The regulator satisfies itself, w/o an accurate
reference voltage it doesn't know & doesn't care what voltage is actually at the battery.
EDIT: I am going on the assumption that You have a std. '72 squareback alt. and
2 wire electronic regulator..........................
This issue has been addressed a number of times before, so You're not alone. 67Dart273 has posted the wiring diagrams a number of times, get that first, then checkCorrect with the regulator and alternator. So where should i start to check the bulkhead connection?
So the voltage spikes when the regulator IS grounded. When it isn’t the voltage is low (maybe that cuts off the charging from the alternator).This issue has been addressed a number of times before, so You're not alone. 67Dart273 has posted the wiring diagrams a number of times, get that first, then check
the voltage working Your way from the feed through the bulkhead at the connections in & out of the ign etc. looking for a drop. Back out through the bulkhead and on.
Sometimes I have to use a headlamp with leads and a probe, it should lite bright the whole way from one end of the system to the other, it's a good "load fail" indicator.
It's easy to light a tiny test lamp/led, and to that end You would really go right to the regulator first and check the blue wire key in "run", bright headlamp and good V
(within .4 of V at the Batt) then the problem lies elsewhere. If You've got points, unplug the dizzy so 'Ya don't burn 'em up while testing.....................................
The regulator (blue wire) is seeing 11 volts while the battery is at 12.2This issue has been addressed a number of times before, so You're not alone. 67Dart273 has posted the wiring diagrams a number of times, get that first, then check
Yes, as suggested above, the regulator needs to be grounded......but a poor ground results in what you've just observed. So a poor ground will result in poor charging,So the voltage spikes when the regulator IS grounded. When it isn’t the voltage is low (maybe that cuts off the charging from the alternator).
Any ideas on a way to get my voltage level? I was told bypassing the ammeter might correct it.Yes, as suggested above, the regulator needs to be grounded......but a poor ground results in what you've just observed. So a poor ground will result in poor charging,
not over-charging. The reg is grounding the green field wire coming from the alt to generate the field in the rotor windings, controlling the duty cycle to maintain the set
voltage. If You're losing 1.2 volts, that could get You to 16V, and since that blue wire is powering the field, the more the reg grounds the rotor the more current it uses
helping to drop the local voltage there.
I checked the voltage at the bulkhead and the regulator but i'm not sure where to test from there. The voltage loss has to be before both of those point because they're both lowBypassing sending all the charging current through the firewall twice and the ammeter is always a plus, there have been a few ways it has been executed, but none are
going to fix this problem. You need to check all the engine and body grounds, then do what I suggested in post #10. If You have a voltage drop, You have to find & fix
the culprit.
