Fuel sender hook up
roadripper
Brandon,Manitoba
We're building a 71 demon just put the new tank and sender in 3/8 line to carb , where does the other line go to ???
Any help would be great
Thanks Mike
That is an aftermarket sender, the factory ones never had two fittings. How 'stock' is the car and what are you doing for a vent, that is.........does your car (did have?) the factory evap vent system, or an open vent?
So there is no factory vent lines under the car i think at one time it had the factory evac vent but don't know what to do with this line ??? if I plug it will it create a fuel delivery issue ??
Do a search and find some of these, I'm sure it is meant for a return line and not a vent. If your tank originally had the trunk can vapor separator, there should be more than one (4) vents from the tank to that can, and then "the" vent was the 1/4" line which ran all the way up front to the carbon can system. You cannot plug the vent. There are a few ways but it depends on what you "have" and what you want to do
If this is a replacement tank it "may" have just one vent line.
Still another way is to duplicate the 69/ earlier vent which was a nipple up high in the trunk for the vent.
First is you need to figure out what your tank has, that will dictate your options.
Go to Mymopar and download the 70/ 71/ 72/ 73 manuals, and you will see the differences in the system. Part of it is detailed in "fuel" and part of it is in the back of the book in "emissions"
What to do with it all depends on where the end of it is located in the tank !!!!!!!!!!!!!
