panheadchuck
its up against it however its not being used right nowHow far (inches) is your condenser from your radiator??
Treblig
Treblig
i have the fans that champion offers with their radiators 2 fans and a shroudGet better e-fans that actually pull some amps and give ya at least 3k cfm or better.
Gauge is a new auto meter ultra light electric , It matches the reading in the MSD handheld from the coolant temp sensor for the injectionCheck your gauge too.
10-4 ill do thatThose fans aren’t any good for cooling a lawn mower. Get better fans.
what fan setup are you running ? i have the ones that come with the radiator package from ChampionOver generalize much?
A 3 row radiator is not “very inefficient”. Is the 3rd row generally less efficient than the first two? Sure, in general. But the design of the radiator, size and shape of the tubes, spacing between the tubes etc all play a part in that efficiency. There are three row radiators out there that will outperform two row radiators, and two row radiators that will outperform 3. There’s a heck of a lot more to it than just 2 vs 3 rows in the core, so you can’t just throw out blanket “20% more efficient” claim either. That’s as much nonsense as a horsepower rating calculated by the manufacturer.
And I run a Champion 3 core 26” radiator in my Duster with a 400-ish hp 340 that’s punched out .060” and have never had a problem with it overheating. Quite the opposite, it’s managed just fine even stuck in traffic when it’s 110*F outside. Usually the the dual electric Contour fan set up I run stays on low speed, I’ve only ever had the high speed kick on a couple times.
14 at idleHave you checked your plugs to make sure you are not running to lean, or rich ?
That's good, the more space you have between the condenser and the radiator the more cavitation you get as the air passes through (even with fans). If it's up against the radiator that should not be a problem. The cavitation occurs whether you use the AC or not.its up against it however its not being used right now
I run a 1995-2000 Ford Contour OE fan set up. Dual speed, dual fans, fits great on a 26” radiator. I use it with a Dakota Digital fan controller and dual relays. The dorman made replacements are like $130, and they put out 3,000 cfm on low speed and 5,000 cfm on high speed. Been using it for a few years now daily driving my Duster, works great. My install is here, I have all the part numbers listed
My "new" '74 Duster- or why I need a project like a hole in the head
what is the actual part number of the radiator? On champions site they list three and they all seem to be 22" mine is a cc375 3 row with dual 12" spal 1522 fans , 1328 cfm each. clearly i need to do the contour conversion . i may just buy whatever radiator you are using. my core is 26" wide x 17" TallI run a 1995-2000 Ford Contour OE fan set up. Dual speed, dual fans, fits great on a 26” radiator. I use it with a Dakota Digital fan controller and dual relays. The dorman made replacements are like $130, and they put out 3,000 cfm on low speed and 5,000 cfm on high speed. Been using it for a few years now daily driving my Duster, works great. My install is here, I have all the part numbers listed
Champion radiators SUCK for their consistency. One may cool great, then one is a POS. Plus, as stated, you have the three row. Ultimately the radiator is responsible for how hot your engine runs. That's where I would be looking.
It's cooling down to 196* on the road, which means the radiator isn't likely the problem here. We know his fans are a little short on CFM, and that's shown by the temp climbing at idle. There's nothing wrong with 3 row radiators, they're used frequently and work just fine in all kinds of applications. A 3 row is not inherently worse than a 2 row, it depends on the construction of the individual radiators.
The thermostat should set the lowest temperature that your car will run at under any conditions, not the capacity of your cooling system. That being said even 196 may be an issue if something is being overtaxed.
