Snake
Mopar Nut
Well the 71 is on the road,every thing new in the front end everything,but there is a lot of creaking going on,all oem rubber,it happens when i push up and down on the fender.WEAR to look,any thought out hear. thanks.
the lower weer torqued under load,the upper weer tighten under load but not torqued i have yet made it to the alienated shop but are snug for sure.Were the lower control arms pivot bolt nuts and upper A-arms cam nuts torqued with the suspension under load?
just a thought....
or just crank the tunes up.1) don't push down on the fender. 2) When yall are ridin around, just talk louder.
