69wacuda
Handling, and a 500ci engine.... All in good time!
So, I've been trying to drive the barracuda more lately, and all of a sudden, after two days of driving it, it doesn't start. I jump it, let it run for 20 minutes and then let it sit for most of the day. I go to pull it in the garage at the end of the day and it's dead again! I jump it again and pull into the garage. When I turn the key and pull the key out it's as if i hadn't done anything. It just keeps running. I replaced the ignition switch; no dice. That was $60 down the drain. Could it be the coil? Any help would be appreciated.
Thanks,
Grant
Thanks,
Grant
