Have a look at this bushing.
Snake
Mopar Nut
Belleville Canada
This is upper control arm bushing,it looks like it missing that washer that has bumps on it to bite in when its tighten,please have a look and tell me if so.that creaking noise is back.
I think he probably removed it to show us the lack of that washer. Moog offsets do not have one integrated. After 66 they did not have a washer on the outboard: this is <67
here is a later model with no integral washer
but I believe it uses a floating one too.
Hard to tell for sure from a picture. It wouldn't surprise me if it were missing as some bushings are sold with out them or someone "couldn't get the a-arm in with it on".
Here's an A-body bushing end measurement if it can help..….
ya the pic is not too good this pic is off my old 69 dart,as you can see the washer with barbs around it is there ,i will get a better close up of the bushing.
You might check that hole dimension. Would that end in the picture I posted fit in there? I'm thinking the bushing steel should have a c'bore to accept it if it were designed to have one.
Based on what pishta has posted, do you think your bushing is missing the collar/integral washer?
What additional information do you need? You’ve posted the same question on FBBO so why not hang tight and get the second opinion there?
Aftermarket ushings had the washers but factory did not. At least the NOS ones I had didnt.
Does anyone know if I can still get those collars ?
After looking at Pishtas pics I may stand corrected... my memory may be tricking me... but I do recall thinking the Moog washers looked odd when I opened the box
Your supposed to remove the old washer from the bushing and reinstall it in the new bushing. I have done tons of them. It's common sense, really.
Your style suspension requires those washers at both ends of the bushings.
Well i took of that arm,dont let me work on your car ever what an ***,i think its time to give up on this hobby,this is what i found.
Looks like a lower Control arm bushing ?
Anyone that denies ever screwing something up while working on their car is either a pathalogical LIAR or..... they dont drink !
Dont know which is worse.....lol
thanks bro i need that
So what shop did the work?
So did you have the right bushings originally? Did you supply the bushings or did the shop buy and install the bushings? Are the new bushings different from the ones that squeaked?
Where was(were) the error(s)?
There is a whole post on stupid stuff we did, but were all still here! I replaced a crank with the motor STILL IN THE CAR and I forgot an upper crank bearing shell! :BangHead:
