I share the same retention...lol... I try for .010-.015... but once you tighten it back down and torque it you usually find that there's always a lil extra still..030 is ok but if you are AR about it you can shim them to .015. That's what I do because I'm retarded like that. If you have to shim to .030 why not close it up a bit more.
Just between the rockers and not the retainers correct? Are they metal?They go on the shaft between rockers as needed.
Mopar Performance P3690896: Rocker Arm Spacer Set .015" Thick | JEGS
It's definitely not a lifter tick. It could be some of the causes you named. Thanks for all the input.
agree w/ this ^^^^^^^^^^^^^^^^^^^.030 is ok but if you are AR about it you can shim them to .015. That's what I do because I'm retarded like that. If you have to shim to .030 why not close it up a bit more.
Sometimes you end up grinding on the hold downs to get it just right.My cam is hydraulic but, is on the larger side. I was wondering if that had anything to do with it. Could someone post pics of the shims and exactly where they placed them?
Running the hydraulic lifter adjustment out of range?Thanks. A friend of mine who is career mechanic has been doing some research as well. A lot of guys are having this issue. Some have found it was the thickness of the head gaskets causing the problem.
