dodgefreak8
- Joined
- Nov 27, 2007
- Messages
- 168
- Reaction score
- 124
I'm 6'2" and the bucket seat in my 72 dart sport just won't go back far enough to be comfortable.. any tricks? Can i move the seat brackets back? Thanks
yes yearone makes a set or you can make your own. Single Part Search Result For SB246I'm 6'2" and the bucket seat in my 72 dart sport just won't go back far enough to be comfortable.. any tricks? Can i move the seat brackets back? Thanks
Check your bases, some have 3 holes & the stud is normally in the center hole if so.
AJ, how much do the rx7 seats weigh ? Mighta asked this before -----------I mounted a rectangular plate on my tracks, then mounted my seat almost exactly where I wanted it. This made it a little higher too, and now I don't look like a midget in there anymore.And it got a little easier to get out with my lowered ride-height. And the clutch pedal works better. And yes I still have room for a helmet. And the window-sill is still uncomfortable for my arm,lol.I am running old RX-7 buckets.
I never scaled them, but I bet less than half that of the stockers.AJ, how much do the rx7 seats weigh ? Mighta asked this before -----------
cool, wish I could be that lucky ! LOL Would u have time to weigh one ??I always remove the spacers under the seat tracks, but head room is my issue, not leg room.
BTW I found a pair of rx-7 buckets and tracks in my dumpster a couple of months ago...
Not bad shape- one 3/4 inch rip that's hard to see.
...along with the twin turbo setup from the same car!!
thanks, might be worth looking into .I never scaled them, but I bet less than half that of the stockers.
Dolls come in small sizes too !These work great, I used something very similar, except in have the opposite problem as you all.
I moved my seat higher and forward because I am 4'8" ....... but this type of brackets work either way you are going
Longshot being this is an OLD thread....but how do these work?These work great, I used something very similar, except i have the opposite problem as you all.
