fuel pump draining back to tank
KJoeZ61
Northampton Pennsylvania
I bought a cool carb kit last weekend at Carlisle for my Quick Fuel. So I went to install it today and noticed when I disconnected the fuel line at the filter it was dry. It's been hard starting when sitting for several days or longer. I replaced the fuel pump for the same reason last year. It's a Delphi from AutoZone. Anyone have a better place to buy a stock fuel pump?
The cool carb kit. Only had it on and drove for about 45 minutes and restarted without a sputter. So far I think it's a big improvement over the Edelbrock insulator gasket I had on. Idled much better at stops, so far I'm impressed. Blaming both of the issues on the ethanol. Even before I put the Edelbrock insulator on and just had a gasket, you could see the fuel boiling in the carb.
Did you buy the thick, or standard?
Interested if this works for you.
not the ethanol...gasoline is blended for fuel injection...not carbs...so i evaporates fast...
Bought the thin one because I have a height issue. This includes the base plate and spacer and 3 gaskets. All in all it only goes up about 1/2", but I see a noticeable difference. Don't know about the blend, but this summer in Pennsylvania the gas sucks for old school cars, and I still blame the enathol!
My question was "better fuel pump recomandations?"
water don't run uphill, and neither does gas.
There is only one way for the gas to actually return to the tank, and that is if the tank is not venting, and develops a vacuum.
More likely is that the pump is sucking air.
Or that after the engine is shut off, the fuel is boiling in the line, when the float drops..... due to it boiling in the bowl. Then possibly the vapor pressure in the hot tank, forces fuel up the line and it boils in the pump, and the fumes escape thru the now continuously open float-valve.... Next morning the tank has cooled off, the vapor contracted,and it pulled the fuel back.
IDK I like the story.
Check your venting.
Check your venting.
A big problem with AFB/AVS/Edelbrock carbs. I bought a insulator as well. I have been eyeing them at the Nats for a few years. Like the owner said, Edelbrocks have a very small float bowl that sits right over the intake. It's very easy to boil/vaporize the fuel during a hot soak.
A simple electric fuel pump takes care of empty bowls in about a second.
Having cooler gasoline is a good thing, and an insulating spacer always helps with that.
Your check valves are leaking. This is what I use with a dead head regulator and 3/8 fuel line from the tank for steady 1/4 mile WOT flow. Summit regulator is set to 6.5 psi OOTB.
Carter Strip Super Mechanical Fuel Pumps M6270
Here is my non scientific observation and poll. I have been working on quite a few mopars at my place over the last few years and noticed the cars with Carter or Edelbrock carb's after running stink up the garage for a couple days due to evaporation and are hard to start due to dry carb's after a few days. The cars with Holley carb's don't smell and restart easy weeks later. So at a car show with a number of Mopar owners there I did a survey and found the same results.
That's actually what I was thinking. I have a Quick Fuel HR-650 on it and it's great, but I was told no more than 6psi of fuel pressure. So if I go with the Carter I would need a regulator, right?
Yes. Run the regulator as is, it is set at 6.5 from the factory. I run a demon and QF with this regulator and both of my cars run great.
One thing to keep in mind is that a lot of people talk about the fuel getting or running back to the tank.
The only fuel that runs back is what is in the lines, as it is not physically possible for the fuel in the carb bowls to run back.
Evaporation is what empties bowls.
On another note, I know a lot of people don't like the thought of running an electric pump.
The electric IS the way to have instant fuel in the carb and instant starts.
After the electric my car starts pretty much before you can get your hand off the key.
Here's a video to prove it.:D
This is first thing in the morning and the car had not been started since early the day before.
(Neighbors mower was running in the background)
www.letsgocomputers.com/dart/morningfire.avi
the eddy/carter carb accelerator pump well does not extent itself down to the bottom of the fuel bowl so once the gas evaporate below the well....you have no shot to start the car....the holley accelerator pump is on the bottom of the bowl and there for will provide a shot of gas longer....
my e85 carbs on the race car sit for month and still squirt gas to start the engine....that is 85% ethanol...
it was dry even in the filter.
