N1ce2k1llu
Does anyone know what this is and if it's fixable? Not looking for "fix it by replacing it" answers.
It was like that when I bought it. Doesn't clean off, like it's in the middle.Almost looks like primer overspray
The cloudiness could be caused by de-lamination, the OP stated it wouldn't clean off.If it is between layers of glass a little heat may make it go away. Be very careful tho..
Windshields are typically laminated glass. Side glass is typically tempered BUT back in the day (my 56 Ford PU for instance) the side glass was laminated as well. Don't know when all side glass changed to tempered.Isn't all automobile glass "Safety Glass"?
There ya go. If it cant be felt with a blade, its inside. We need more info. Where you at!? Reply!Stop by your local glass shop. May be they could tell you. You may have to replace it.
It's on the outside. Tried paint thinner and a razor both had no effect.There ya go. If it cant be felt with a blade, its inside. We need more info. Where you at!? Reply!
Glass shop will probably say, "Replace it", lol.
