Depends.......many aftermarket radios have a separate wire for the dash lamp just like your original. If not yes, tape it off. Put it in back of your mind, IE you install an accessory gauge panel, there is your lighting tap.
If a radio has a separate light wire- then it is tied into dash lights and will dim. If a radio has no separate light wire- then the light in the radio goes on with the radio and is not dimmable.
Ok, so the aftermarket radio (older am/fm cassette) has a yellow wire that shows it going to a positive separate from the red. It does not say dimmer, but I guess it will go to the orange-right?
