[SOLD] Last set! 11 inch 8 3/4 backing plates with parking arms & separator struts $100 shipped
gregpurcell
Greg Purcell
Near Savannah, GA
I sold one set already and I have one more!
This is a set of 11 inch rear backing plates with the separator struts and parking brake arms. Located in Savannah, GA.
This setup will work on most big bolt pattern 8 3/4 rears including A body IF you are using aftermarket axles.(They will NOT work if you have stock A body SBP axles that were redrilled to LBP)
This setup will also work on Dana, 91/4 and many 81/4 axles. $100 shipped in the US
How much shipped to Canada? Postal code is L0M1B0. Thanks.
The brakes fit in a USPS medium flat rate box which ships to Canada for $48. However to be fair, I was offering them for $100 shipped in the US so I should deduct the cost I would have paid to ship to a US customer. The medium flat rate box IN the US ships for $14, so $48-$14=$34
