Lazy ***... It's 4 bolts!Exactly. When the carb or carbs are too small, they tend to go dead rich and it's hard to correct.
Exactly. Overall flow in terms of flow numbers, but more importantly flow QUALITY is better. So you need less cam timing to keep the RPM the same. And the TR will make amazing low end torque while not giving up anything on top. If you don't reduce the seat timing, the bottom end goes to hell, and you have to spin the guts out of it to get the power back. That is an over cammed issue and not an intake issue.
Look at modern EFI intakes. They are nothing more than laid down tunnel rams. You can't do that with wet flow like a carb, but dry flow with EFI makes it possible.
Like I said...I have a perfectly good TR under the bench in the shop. If my car didn't have the factory Raisin Bran hood, that beeeeeeeeotch would be on my car.
Good enough? LOLJust thought you may want to chime in on this one?
Good enough? LOL
This intake juxtaposed with the washing machine says something.... I just don't know what... LOLIMO, if your going to use a tunnel ram in the street, then ether the current Weiand or the below Edelbrock with the smaller/thinner plenum.
The M1 is a race intake.
The Weiand and the below Edelbrock (with the pictures top) would be best for the street.
Everything is in its cam, carb tune & useage.
Would there be an advantage to isolating the front and rear halves of the TR? Essentially create a V4 fed by each carb? The tops are replacable, so it seems you could pretty much fab whatever you wanted for plenum volume on top. Go a step further and with two FITech or Snipers on there with the plenum isolated to each bore, it would be like having individual throttle bodies on for each cylinder which should give good response and help with the idle and part throttle tune?
Huh?This intake juxtaposed with the washing machine says something.... I just don't know what... LOL
No, as mentioned, the carbs like to see a constant signal on this kind of set up. Carbs generally don’t like to start and stop. While fuel injection helps, the style best to use would be sequential port injection. Not a divided twin throttle body up high.Would there be an advantage to isolating the front and rear halves of the TR? Essentially create a V4 fed by each carb? The tops are replacable, so it seems you could pretty much fab whatever you wanted for plenum volume on top. Go a step further and with two FITech or Snipers on there with the plenum isolated to each bore, it would be like having individual throttle bodies on for each cylinder which should give good response and help with the idle and part throttle tune?
This is a little bit of a different animal. It has every update we wish we could provide and then some. It has every advantage plus. But in a way, yes, you are correct. However, doing this on our older engines would require some serious fabrication skills. It is not undoable but just simply difficult. And probably cost prohibitive.Reason I ask is I've got a 2000 BMW M5. It is a 400hp 5.0liter motor that has individual throttle bodies for each cylinder with a 6-8" horn feeding each one. All hidden in the big box plenum. The throttle response of that motor is fantastic and I've been led to believe that part of that is due the individual throttle bodies.
Now is t it funny how a tunnel ram will work wonderful with 2-750’s where the single 4bbl. is limited by one carb? Even if it was the same size (750) or larger, the total cfm of the twin carbs is more than what you could reasonably put up to with one carb.As was posted earlier, stay moderate with your camshaft if street driving the tunnel ram and spend the extra money for a calibrated pair of carbs. Forget 390/450cfm carbs unless you have a flathead Ferd. A friend took a 750dp/single plane (Victor) intake off his hot 340 4spd Barracuda and replaced it (at great expense) with a Weiand tunnel ram and 2 x 450s. Guess what? He slowed .5 in the 1/8, regardless of tuning. I begged him to go bigger with the carbs and he finally did. With two (cheap shelf units from Summit) brand new ProForm 750dp's, he got back his .5 plus .3, for .8 second total improvement over the single plane/carb, even with the sketchy ProForms.
Mine is an old Weiand and it has a single four barrel top. When I swapped out the torquer single plane on a 383, I used the same old 850 do with no mods. The car went from 12 flat to 11.8 with no other changes except for cutting a hole in the hood.
