QA1 Aftermarket K-member Problems?
That is the idler. You want the pitman arm also?
From the QA1 pic, it looks like they moved the idler arm mount forward 1" or you could correct it with a +1" idler arm. Hard to tell from the pic as it is not shot perpendicular to the center link. They could not move the steering as it would affect the existing steering shaft length.
After re-reading this thread I went and looked at mine real close. My center link was higher on the drivers side by 1/2”. I’ve always had a problem with the TTI headers not fitting correctly, shimmed the drivers side engine mount by 3/8 and still had to dent the bottom 2 tubes to clear the pitman arm nut/stud.
It had always bugged me, engine tilted to the passenger side, dented $800 headers and still the pitman arm stud would drag on the tubes.
So my buddy stopped by with the flaming wrench, a bit of heat to the pitman arm, slight bend and now the center link is level and the pitman arm stud clears the tubes. Turning is still as it was so I’m calling done.
Any chance you could post a pic of the bent pitman arm.
Years ago I used to hear of people heating and bending their pitman arm to improve toe pattern.
Do you have any before and after pics?
Where can you buy a +1 inch idler arm. Never heard of that.
I didn’t take a before pic, but here’s where I bent it.
