74Scamp
Hopefully I can get pointed in the right direction here. I have a 91 LA 360 that might be turned into a turbo project on e85. More than likely I’ll run a GT45 turbo and would be around 600 hp. The heads are gunna be worked over and a boost friendly cam will be installed. I know the stock crank should be ok on 600 hp of use but I’d like to at least get forged rods and pistons. I cannot find just a set of pistons and rods without getting a stroker kit. If the block needs bored .030” that’s fine but I’d rather not run a stroker kit. Anyone have a link to some forged pistons and rods?
