Thanks guys. I will PM about the replacement bolts. The rubber isolator in that shock is tore up too. So it would need to be replaced because as it is, it might accelerate the stress on the new bolt.
And no, i don't care AT ALL about the air shocks. It's just what the car came with. The front end rides like a dream. The rear rides like an ole hay wagon. And the air shocks slowly bleed pressure off.
I have zero experience with with shocks ... how do I know the right shocks to choose? I'm guessing it would have to do with the static ride height and the distance between the shock mounts when parked.
Help a brother out. Which is what you guys are doing already, and appreciated.
7milesout
