LivewireBlanco
Any tips or tricks to make this install smooth and easier? 1971 Dart.
Boil the rubber grommet on the stove for about 10 minutes. That will soften the rubber up a lot. Then it will pop right into the gas tank. Apply some dielectric grease to the grommet once it is in the tank and the filler neck should slide right in very easy.
I cleaned and reused the old tank. A seal I purchased from another supplier (without investigating first), the tube would not go at all. I suspect it's for an earlier model....But I think my problem is … the replacement tank.....
