No cork, no end seals. RTV or other. All I've ever used is RTV
As far as getting the manifold back off I always run an exacto knife through that double bead in the front and back.I’ve only used right stuff but it sucks to get off. Was hoping there was a better way. I guess not leaking trumps easy removal.
Remember there's always three fingers pointing back at you? What are you putting down now?Those 2 are a couple of f-ing clowns!!!
Laid a bead of RTV (1/4" in diameter) and let set until tack free. A little bit of fresh sealant at the end and put down the manifold. No leaks.
yes good. but what did they do and seal with back then. need answer. what ever it was it sealed. correct?
so your blessed as she. what u after? on install. $ or help..It was unmolested factory parts. That’s like expecting dolly partons first bra to fit again.
