Dennis Hilliard
I know this has been a problem here before, I should have done a search here before I bought it. After spending hours trying to get it to work I am done. After a long hard battle getting it to bolt up it now hits the dust plates for the rotors under full lock and I mean hard, I even tried using the bracket that bolts to the shock brackets also. This car had a factory sway bar at some point since the LCA had the brackets.The end link bolt that I got with it was 5 1/2" long and I just could not get the end link's bolted together so I bought a bolt that was 6" long and a spacer1/2" longer and it worked but not by much. Even if the 5 1/2" bolt would work it would still hit the dust plate's,the bar seems to be just to wide for this car. I called Addco to check on how wide it should be and the one I have seems to be right from the info I got. So what are most guys using here for front sway bar's?
