Clutch Adjustment
No idea, was on it when I bought it.
If it's big and ugly is a Lakewood. There is a very remote possibility it's McLeod but I doubt it.
Those were the only choices up to just recently.
You can get a window out in the can if you want. If all you are going to use it for is adjusting freeplay it isn't worth it.
If you are going to tune the clutch than you need to get a window in the can.
what about if you're just going to let it lay on your garage floor forever and then sell the car?
Bet they do. That's how I do it. If there is ANY freeplay and you don't ride the pedal then you are good to go.
I slide under the car, pull the fork to the rear so the fingers touch the bearing, run the adjusting nut up to just touching. Then I back it off until there is a 1/4 inch of freeplay at the pedal and lock it down.
It's how I do them all. Did it on my race car that I shifted at 8500.
For my semi retarded cousin I used 1/2 inch of freeplay. He rides the clutch like a *****. So he gets more freeplay.
All that dicking around with looking at the fingers is a waste of time IMO.
But in escence you are adjusting the gap between the bearing and the fingers. I do it visually and you do it with pedal free play. Real race cars have clutches that are adjusted with feeler gauges through the top. :poke::poke:
Who has a real race car?
It's still the same adjustment. I did actually go back out and look at the car today. I'm hoping I get a call from a guy tomorrow to come look at it on Sunday. He only has to drive about 4 hours to get here and not 9 like the other jackoff who doesn't listen.
So yes, even if the car sits around, you still adjust the clutch the same way.
True. You are still setting the gap at the fingers. I just don't bother looking in there. I'm old school.
Yes I do. Not you!
(My son driving)
It's a pile of crapola, but it's my pile...
I have a 69 dart with a 340 4 speed transmission. When I bought it, the clutch was releasing when the pedal was 1/2" off the floor. It is hard to get in gear unless I really push the pedal hard on the floor. I wanted it to release closer to the top and bought all new pieces for the linkage as I thought that was the problem ..Wrong. The car came with a scattershield so there is no way to inspect what is inside. Any adjustment tips ??
The first thing I would say if you're Street driving it I would definitely put a diaphragm clutch in it when the time came. I've ran one even drag racing and while they're a little crappy racing they're great on the street and easy-to-use and almost maintenance-free. And nothing expensive, just a good heavy duty clutch.
Now on the other hand if you're Racing for points and competition definitely have a window put in it and keep the three-fingered clutch. My-2.
I had a similar problem trying to get my clutch adjusted and was also eating throw out bearings. Couldn't get the release point up where I wanted it. Turned out that the fork pivot was cracked and was flexing where it bolted to the scattershield so it had been a moving target.
Yes I do. Not you!
(My son driving)
That's a street car now.
Anytime you're ready...
Like I said...you won't know the day or the hour so be ready. We are talking Delta Park right because I ain't going to woodsmokingasshotburn.
Also, I want to show you where I made money in HS if we can get in there. Then we can see if you can drive on the street.
Can we take this where it should be and stop mucking up this poor cats thread?
SNOWMOBILE.
I apologize the the OP for my vile snowmobile comment, but Jpar deserved it.
backfired on your shelf that's my magic word and that's your Kryptonite do you want to talk about snowmobiles all night? I started a thread on it and the political forum.
I don't have to apologize to the original poster he can tell I would rather be somewhere else with this.
