Do like the 6 pack does. A drain on each side. I’ll have to check the size of the tubes that are in the AAR style set up I am doing but I think there generous in size, like a 1/2 inch.
Any memory of a source on this? It would be interesting reading.
Thanks!
I didn't bother with a scoop for my streeter, which seldom sees over 65mph. But I bought a nice oval aluminum air cleaner housing and mounted it on top of the hood, between the inserts.
On the street? Whoa! That's waaay outta my leagueI had to run a scoop because the throttle body wouldn`t clear, even w/ a drop base air cleaner.
I didn`t really want to, much like the roll cage, but needed the scoop, and the cage to stop the body from twisting . We twisted a 67 hemi belvedere body back in the day.
Light weight...On the street? Whoa! That's waaay outta my league
3 to 4 tenths, on this. It was sealed. View attachment 1715226349
that is a bunch for that type scoop !3 to 4 tenths, on this. It was sealed. View attachment 1715226349
Cooler air charge is about the only benefit from a stockish scoop. In order to get ram air effect the scoop needs to be up in the air stream, a 6 pack scoop is not tall enough from my research. I would seal the cleaner to the underside of the hood.
Here is my solution to seal it. I ordered an 18" aluminum baking pan, cut the center out, riveted the cleaner base to the pan. Added a push-on bulb seal to the rim. Added a Wix 4" tall filter. Better than sucking in hot air.
View attachment 1715225384 View attachment 1715225385 View attachment 1715225386 View attachment 1715225387 View attachment 1715225388 View attachment 1715225389 View attachment 1715225390 View attachment 1715225391
