AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 26,608
- Reaction score
- 13,844
The SAI is telling you something, otherwise it's driveable.
Those numbers aren’t that bad. I would expect another degree or so on the caster with the offset bushings, but ride height, both front and rear, as well as the rake, can make a big difference.
Did you do anything other than change the strut rod bushings?
Run it.
2.5 to 3 degrees positive caster with just offset UCA bushings.
Take the $200-300 for tubular UCA’s and buy a front sway bar or 1” torsion bars.
Just wanted to say thanks. Car drives amazing. Been through a couple tanks of gas already.
Were there other changes since the last time you drove it ? ?
Torsion bars, bushings, shocks ball joints, etc....???
