DGrace
Gathering parts for my fuel system and wondering what some of you guys are using. Previously ran ss braid but notice there are so many options these days. Cost is always a factor but don't mind the extra expense if the benefits are worth it. Building a 470 going into a '73 Dart Swinger. I have a Summit 10 gallon aluminum cell, picked up an Aeromotive A1000 pump that I got a deal on ($285) and a Platinum Series 100 micron inlet filer that I also got a deal on ($60). Plan on the matching Aeromotive return style carb regulator and -10 supply and -8 return hose. Carb will be in the 850 - 950 range. Considered the push lock style for its ease, lightweight and cost - also a nylon style braid but heard it was a bit of a pain to work with ( getting all the loose nylon strands in the fitting collar?). Could always use the ss stuff but wanted a black hose. Any help/advice with any hoses you've used would be appreciated. The car is mainly " street" with an occasional 1/4 mile blast. Thanks in advance. <><
