Replacement fuel lines?
Troub
67 Dart 270, 225 slant six
Florida
hello all,
I'm looking for pre-bent fuel lines, main line tank to front, fuel pump to filter, filter to carb. (At least that's how my Dart was set-up when I got it). All the usual vendors list the front lines as fitting 2BBL carbs, 4BBLs, ect.......none that I see for a 1BBL. Also None that I see really look like my current ones.
Any help is appreciated!
hello all,
As far as the carb goes, the only difference should be the line from the fuel pump to the carb. The rest should be the same. Just make sure you get the correct line for swinger or sport depending on what you have since there is a slight difference in length between the two.
It's a 270 with 225 slant six, I'll take some pics of the engine bay lines tomorrow and post. Thanks For the reply Mike.
Contact Inline Tube, if you have originals they may be able to help you.
They did a set of 8-3/4 brake lines for my C-Body that they didn't have listed.
Alan
I bought stuff already bent, but it did not fit my wagon. I ended getting raw tube and bending my own. Good luck!
