perko
Hey everyone, i'm trying to figure out a no spark problem i have. If I were to ground the ignition coil wire that leads to the distributor should I expect it to spark kind of like testing a spark plug?
Yes but..... Grounding charges the coil, ungrounding causes the spark.If I were to ground the ignition coil wire that leads to the distributor should I expect it to spark kind of like testing a spark plug?
